Thanx in advance...and I'll be putting in Mobil V-twin 20w50 oil. Will this affect my warranty? Will the V-twin specific additives cause the more rearward cylinder to cool too much?
On oil filter change
1984 R100: I just dumped me sump and pulled out the filter. I remember a post stating that there is a ball and spring inside the cavity that should be checked. Is there a quick method? BTW will you guys re-use the big white O ring and shim if they look good?
Re: On oil filter change
Uh oh.Zombie Master wrote:1984 R100: I just dumped me sump and pulled out the filter.
YesZombie Master wrote:I remember a post stating that there is a ball and spring inside the cavity that should be checked.
YesZombie Master wrote:Is there a quick method?
The BWORing can be re-used but only by Ron Jeremy, and not for his oil filter.Zombie Master wrote:BTW will you guys re-use the big white O ring and shim if they look good?
Zombie Master wrote:Thanx in advance...and I'll be putting in Mobil V-twin 20w50 oil.
This oil will cause your cylinders to pivot into MotoGuzzi position.
Zombie Master wrote:Will this affect my warranty?
No.
No, but it will make your timing uneven and make your exhaust note sound like a tuber.Zombie Master wrote:Will the V-twin specific additives cause the more rearward cylinder to cool too much?
- Airbear
And the quick method to check the ball and spring is to poke a wooden cooking skewer in the hole. A gentle push should indicate that the spring is behind the ball and that the ball seats back into place nicely. Pat self on back.
If it does not, poke ones self in the eye with the same wooden cooking skewer, it will feel better.Airbear wrote:And the quick method to check the ball and spring is to poke a wooden cooking skewer in the hole. A gentle push should indicate that the spring is behind the ball and that the ball seats back into place nicely. Pat self on back.
Thanx!
Have you seen the size of that O ring? RJ must be a girthy fellow!Major Softie wrote:Zombie Master wrote:BTW will you guys re-use the big white O ring and shim if they look good?The BWORing can be re-used but only by Ron Jeremy, and not for his oil filter.
- Steve in Golden
When I had airheads I often re-used the "BWORing". On the oil filter. The Ron Jeremy angle never occurred to me.Major Softie wrote:The BWORing can be re-used but only by Ron Jeremy, and not for his oil filter.ZM wrote:BTW will you guys re-use the big white O ring and shim if they look good?
Should this thread be moved to the Speakeasy? It might need a picture of a scantily clad hotty or two, as well.
Well the original question was a legitimate technical question that got answered, so I think we're OK here. However there was some degradation in the the second part of the original post. Where are the moderators when you need them?Steve in Golden wrote:When I had airheads I often re-used the "BWORing". On the oil filter. The Ron Jeremy angle never occurred to me.Major Softie wrote:The BWORing can be re-used but only by Ron Jeremy, and not for his oil filter.ZM wrote:BTW will you guys re-use the big white O ring and shim if they look good?
- Airbear
I think the Major's 'tuber' comment is very clever.
And I think ZM's masterly use of the quote feature in three posts in the one thread is worthy of acknowledgement.
Well done, ZM. Pat self on back again.
Youse guys are funny.
I don't have wooden skewers for probing my ball, but I do have a chainsaw file.
Ideally, the probing object needs a flat on the end..................much like a chainsaw file really..
The 'flat' prevents the end of the 'probe' from easily slipping off the ball....
I have tried using a skewer before, but the chicken obscured the ball.
