Intro + Help with my custom wiring diagram
Posted: Fri Feb 10, 2012 4:26 pm
Hey all, I didn't see a place to do intros, so I'll do it here. I'm 37 and live in the Philadelphia, Pa area. I recently bought a 1966 r50/2 roller and a 1974 r90/6 engine to go in it. This is my first BMW and it's a dream I've been trying to fulfill for years. I've ridden all of my life and built several bikes from scratch but they've all been Japanese.
When I build a bike, I typically wire it from scratch too. I don't really know why, but I enjoy doing it. I think this will be the 6th bike I've wired. Typically, I build stripped down bikes with the bare essentials, but I want the Beemer to be a little more complex than that. I'm by no means an electrical expert or wiring guru, but I can think, more or less read a wiring diagram, and I can read advice on the internet.
The Beemer doesn't look too different electrically from what I'm used to, but I wanted to post my diagram here and see if anyone saw a major problem with it that I didn't see.
I am using combined reg/rec unit and an aftermarket ignition switch (in a /5 bucket). I've also fused several places that aren't fused stock (ignition, headlight, alternator trigger wire, and a main fuse). I'm also using the /2 hi/lo horn switch, and I don't want to stress that poor thing out, so I put in headlight and horn relays.
Finally, the reg/rec has an orange wire that goes to the ignition switch to prime the alternator. In the stock situation, that wire goes through the the charging indicator light. None of the reg/rec combos seem to show that wire using the indicator light. It seems like it shouldn't be a problem to wire in that light, but I figured someone here has probably already tried it (maybe there is a resistance issue?)
Thanks for looking!
http://i28.photobucket.com/albums/c237/ ... dr90-2.jpg
Thanks for looking!
