Fender forwarding
Fender forwarding
Anyone know if a /7 fender will fit a /6?
I now have a spare fender and said to Airbear he could have it, if it fits his /6.
Obviously there is the option of taking the /6 to where the /7 fender is or vise versa, however that would take effort.
I usually get E for effort :mrgreen:
All responses given A for effort.
Re: Fender forwarding
Front or rear?
R90/6: 15 46611234935 MUDGUARD FRONT PRIME COATED 1.41 1 $228.76
R100RS: 13 46611234931 MUDGUARD FRONT PRIME COATED 1.46 1 $188.32
Well, they're different...but that doesn't answer your question. A big E for me!
Post by Deleted User 62 »
ME 109 wrote:Anyone know if a /7 fender will fit a /6?
The top brackets are the same, it will fit. Just won't need the rear brace if it's a short /7 fender.
Thanks guys, yeah, front fender Steve.
I got me a nice matching 507 painted front fender from Germany for my RS so I now have a spare gloss black job that was a temporary replacement for my roo busted original.
I best get in touch with Charlie.
Thanks Tim!
Are the top brackets or fork braces the same between ATE and Brembro forks?
The mounting holes at the top might be different, nothing a coupla bright fellas couldn,t figure out. :ugeek:
moosehead
Post by moosehead »
Garnet wrote:Are the top brackets or fork braces the same between ATE and Brembro forks?
Yep, the fender bracket is different between the ATE forks and the Brembos forks (bit wider width on the Brembo forks) however the fender mounts on either one i.e. the holes line up for mounting fender on either bracket.
So, think Charlie would be OK to bolt this fender to his ATE forks bracket. :D
I'm just wondering how Brunhilde will feel when she gets this shiny, shapely mudguard. Will it make the rest of her black bits look even shabbier? Her current front mudguard had the leading 300mm broken off when we hit a cow ten years ago. I made a plaster mould of the undamaged back part and used glass tape set in epoxy to join the broken bit back on. The left hand rear bracket had already been replaced with a dodgy bit of steel tube by a previous butcher. It's all patina to me.
So, should I accept this very generous offer from Jeff? O yes. I think this will be the year when I bite the bullet and paint the old dear. She deserves to look a bit more glamorous. She'll be 40 in a couple of years - often a stressful time for a lady.
Airbear wrote:I'm just wondering how Brunhilde will feel when she gets this shiny, shapely mudguard. Will it make the rest of her black bits look even shabbier? Her current front mudguard had the leading 300mm broken off when we hit a cow ten years ago. I made a plaster mould of the undamaged back part and used glass tape set in epoxy to join the broken bit back on. The left hand rear bracket had already been replaced with a dodgy bit of steel tube by a previous butcher. It's all patina to me.
Yes. A nip and a tuck here and there will do no harm. These bikes look better as they age. They are like people in that regard. You see some who are comfortable in their rumpledness and some who never have a hair out of place nor have their hands ever been dirty. Same with the bikes as far as I can tell.
Front fender was expressed posted to Charlies this arvo on the back of my RS.
It was obvious that Charlies fork brace has narrower hole centres latterally than the /7
Only option will be to see if there is enough /6 fork brace to drill some new holes..........
A pleasant couple hours on a sunny Sundee, Thanks Charlie and Jane.
Well, I'm sorry it wasn't an easy fit. I have a R75/6 with a later set of front forks, so at a glance it looked like it would. I did not know there was a difference between the two fender braces. If you need one, I might have a spare. I think the "74 has a chromed one, but the later model was stainless steel?
Last edited by Deleted User 62 on Sun Feb 12, 2012 12:54 pm, edited 1 time in total.
