Hey guys. Here's one for you whizz kids. I'm doing a reverse conversion project:
- /5 frame
- /5 SWB swingarm (I think here lies the problem):ear
- /6 final drive
- R50 engine
- /2 gearbox
There is a lot of information on this site about people putting /5 engines in /2 frames but hardly any info on these reverse conversions.
My question is simple: what is the simplest way to get the driveshaft to work with the earlier transmission. Firstly I think I might have "length" issues i.e.: it seems the driveshaft is a little long. Second, can I use a /5 output flange on the earlier gearbox (I believe both use a 1:6 taper) Am I better off using a LWB swingarm and perhaps the /2 driveshaft? Would the /2 shaft work with a /5 final drive?
So many questions too little gasoline.
Thanks guys
Darren
1962 Manx norton
1968 R50/2
1916 Harley Davidson J
/2 reverse conversion. Driveshaft fun
Re: /2 reverse conversion. Driveshaft fun
One Fellow at the Griffth park had a custom /2 conversion
R90 motor to the /2 tranny with a /6 rear ger box?
so I asked how?
He said /2 drvie shaft and /6 cup and the rest was easy to "fit"
so as I think maybe you use the /2 drive shaft AND /6 cup
so I asked how?
That won't work. I'm using a SWB swingarm...the /2 driveshaft would surely be too long...
Maybe he cut and welded the drive shaft or machined the attchment to use the cup
It might be easiest to move the engine mounts a bit further forward.
- George Ryals
Have you tried the /2 Conversion group on Yahoo? They may know all about it.
Reverse conversion.....newer bike, old under powered motor, old tranny.........why?
Just Postulatin'
Reverse conversion.....newer frame, older motor.........why:
Rennsport!!! Am I right?
I too was trying to figure out why.
Correct...rennsport replica in the making! I have a great hose tank and killer seat to match. Just need some help on the driveline. Thanks guys.
