Clutches and gearboxes
Posted: Thu May 10, 2012 11:29 am
by hools100RS
I'm considering converting a '76 R100S to take later '81 lightweight clutch assembly. My question is ; will such a conversion require the use of a post '81 gearbox (with it's shorter input splines)?I have /5 4speed 'box that will sit behind the standard '76 clutch OK but I'm unsure of how to proceed gearbox wise if I go the post '81 clutch route.
Comments appreciated. hools.
Re: Clutches and gearboxes
Posted: Thu May 10, 2012 1:41 pm
Yup, the later model clutch/flywheel assembly will require the correct transmission. Alternatively, you could open the older transmission up and swap out the input shaft. I think that's a can o' worms, though.
Posted: Thu May 10, 2012 4:00 pm
by Deleted User 287
I could be wrong, but I thought it was the introduction of the mono-shock models that brought the shorter input shaft change?
Posted: Thu May 10, 2012 6:00 pm
It began when they went to the lighter clutch/flywheel assembly. That was with the '81 models.
