1981-84 Brembos
Posted: Fri Jun 08, 2012 12:40 am
I've had a front caliper apart this last week. I was checking the maxbmw fiche and noticed a spacer on the fiche is missing from my set up.
# 7 & 8 in the picture. # 7 doesn't rate a mention in the list but #8 is described as:
11 12 1 336 872 WASHER - 3,5 ZNS (from 09/80)
Could anyone with a 1981-1984 R100 of any sort have a look at their caliper to see if they have it please?
Re: 1981-84 Brembos
Posted: Fri Jun 08, 2012 3:15 am
I've not noticed that spacer Steve, it would have to be put up before the caliper was re-mounted......looks like it goes between the caliper and the slider.......never seen it.
Re: 1981-84 Brembos
Posted: Fri Jun 08, 2012 3:28 am
by Roy Gavin
Number 7 looks like it just adjusts the length of the bolt, to stop it hitting the rivets on the caliper.
Number 8 looks like it centres the caliper on the disk.
So if the end of the bolt doesn't touch the caliper, and the caliper is central on the disk, don't worry about them.
Re: 1981-84 Brembos
Posted: Fri Jun 08, 2012 3:32 am
Yep, that's the spot. I'm presuming the 3,7 means 3.7mm? Seems big. I put a 1.6mm wide washer on them to see how that'd work...can't tell much difference in a ride to & fro work. The caliper appears to seat correctly still, though without removing the caliper again and looking for any offset between the mounting lugs on the slider, it's difficult to tell. I might go do that over the w/e.
Re: 1981-84 Brembos
Posted: Sun Jun 10, 2012 11:18 am
I had a washer as a spacer to test this over 30 ks to & fro work. I'll take the spacer out tomorrow as it caused some pulsing at the lever that wasn't there before.
Once that was evident, I used the rear brake mostly, avoiding the front as much as possible.
BMW fiche not always right it seems, but I think we knew that.
Re: 1981-84 Brembos
Posted: Sun Jun 10, 2012 1:47 pm
by Motorhead
a lot of stuff is not right
do what you need to ride and be safe
