Brembo Fo8 rebuild.
Posted: Sun Jul 01, 2012 10:36 am
This seems simple enough.
However, I don't have any brake grease described for the reassembly. It's used to coat the square section slider seals in the piston bore, and to coat the inside of the seals that sit above and around the outside of the piston.
A very small smearing across the back of the pads is described as decreasing pad squeal too...apparently dampens vibrations that cause the noise.
What should I be looking for when asking for "brake grease" at the local shop?
