Bob Bennett
Posts: 223 Joined: Wed Aug 04, 2010 6:51 am
Post
by Bob Bennett » Sun Jul 29, 2012 1:10 am
G'day Fellars
I'm a bit apprehensive about getting these buggered badges removed from the tank without damaging it any further,
It's not perfect but it does me, so does anyone know a way to do this with no dings or scratches?
Thanks in advance.
Regards, Bob
R80 RS
dwerbil
Moderator
Posts: 2872 Joined: Tue Aug 03, 2010 10:58 am
Post
by dwerbil » Sun Jul 29, 2012 2:04 am
Bob, try using a hair dryer. A bit of heat and the adhesive should come right off.
Click for pics
Randy in Round Rock
Bob Bennett
Post
by Bob Bennett » Sun Jul 29, 2012 2:45 am
That sounds good, I'll try it out, thanks heaps dwerbil.
Regards, Bob
R80 RS
Posts: 8900 Joined: Tue Aug 03, 2010 1:46 pm
Post
by Major Softie » Sun Jul 29, 2012 2:49 am
The hairdryer heat + cutting through the adhesive with some dental floss will even get a stubborn one off.
Posts: 4942 Joined: Tue Aug 03, 2010 3:29 am
Post
by SteveD » Sun Jul 29, 2012 5:44 am
Major Softie wrote: The hairdryer heat + cutting through the adhesive with some dental floss will even get a stubborn one off.
That's the one.
sterob
Posts: 148 Joined: Tue Aug 03, 2010 6:16 pm
Post
by sterob » Sun Jul 29, 2012 7:01 am
You want to preserve that badge?
Jeez, Bob, they are not that expensive. Your bike will look a million dollars with new ones.
Post
by Deleted User 62 » Sun Jul 29, 2012 11:21 am
If you want to get the new badges correctly aligned, put a piece of tape over it with one edge lined up with the horizontal line of the blue / white and overlapping on to the tank. Cut the edge where it leaves the emblem, then you have a way to line it up.
montmil
Posts: 155 Joined: Wed Dec 22, 2010 9:41 am
Post
by montmil » Sun Jul 29, 2012 12:22 pm
Tim Shepherd wrote: If you want to get the new badges correctly aligned, put a piece of tape over it with one edge lined up with the horizontal line of the blue / white and overlapping on to the tank. Cut the edge where it leaves the emblem, then you have a way to line it up.
This little tip is golden.
1981 R65
1983 R65
1978 R100S
1995 Triumph Trophy
