Vibration through footpegs..4200rpm+
Posted: Fri Aug 03, 2012 8:42 pm
Bike: 1977 R100S 46,000kms
Vibration felt mainly thru footpegs begins around 4200rpm and increases as rpm's increase.
Thought was related to loose pinion collar nut but for past few weeks substituded another FD from a 78 R100/7 to get bike back on the road for some riding and sorting out things after the S,s rebuild this past winter...collar nut on borrowed FD was check and on real tight. Vibes still there.
Things checked so far:
Engine mounting bolts checked - all ok
Rechecked timing - spot on
Rechecked valve clearances - all ok
Re-synced carb balance at both idle and just off idle - real good using 2 different manmometers and also my buddies. Also balanced at around 4000 rpm's...very close on meters...not enough to make a difference
Rechecked new throttle cables installed at rebuild to check for routing and/or any hang ups - didn't find anything so far
With bike on centre stand...free hand on footpeg...run rpm's up to 4000...not bad but hit 4200+ vibes start and continue right up to 7000 (didn't go beyond that)
So...don't think carb balance is the root cause...now think its either flywheel/clutch, gearbox input shaft (?) etc....
Any ideas where to look to now? Vibes strictly related to engine/gearbox combination as it happens in neutral, on the center stand.
Add'l Note: Searching through old work orders PO gave me with bike. In 1994 bike went in to "check possible slipping clutch" but I didn't see anything that indicated clutch was replaced or checked. Wondering if they had clutch/flywheel out and its now out of balance if reinstalled out of balance???
Thinking to remove gear box and run engine only to see if vibes are still there...would eliminate gearbox input shaft ????
