Das Boot??
Posted: Thu Aug 09, 2012 3:15 pm
by jagarra
I have a early 74 R90/6 made in 1973 which has some unusal control lever housing, both sides. Just under the housing there is a plunger set up with a couple of wires coming into it, I am looking for the part number for the boot for that assy. The plugger/switches look like they operate the front brake switch and some type of interlock so you can start the bike with the clutch puled in. Of course these items don't appear on the fiche, at least where I can find it.
thanks,
Re: Das Boot??
Posted: Thu Aug 09, 2012 6:08 pm
by hal
pics? I have a early /6 as well and dont know these....
Chhers
Re: Das Boot??
Posted: Thu Aug 09, 2012 8:10 pm
by jagarra
Here is a link to the part I am looking for, don't need the whole thing but just the boot portion.
http://www.bmwbayer.de/Brake-light-swit ... 09/74.html
Re: Das Boot??
Posted: Thu Aug 09, 2012 8:17 pm
by George Ryals
I bought some from Blue Moon Cycles in Atlanta. I think most BMW dealers would have them.
Re: Das Boot??
Posted: Thu Aug 09, 2012 8:24 pm
Part number 61311351646
$5.11 at A&S BMW
http://www.ascycles.com/Illustrated_cat ... at=61_0224
As George says, most dealers should be able to get them, if not have them. They fit everything from '70 - '76.
Re: Das Boot??
Posted: Thu Aug 09, 2012 9:14 pm
by jagarra
YAHOO, thanks Major.
Yep, it was just knowing where to look, kept check the fiche off and on all day, different models. There is another switch for the clutch side, which is the same.
thanks all,
gg
Re: Das Boot??
Posted: Fri Aug 10, 2012 9:39 pm
by vanzen
"das boot" is german, meaning "the boat" ...
Re: Das Boot??
Posted: Fri Aug 10, 2012 10:58 pm
by Chuey
vanzen@rockerboxer.com wrote:"das boot" is german, meaning "the boat" ...
He knew that. These are meant for the same purpose, kind of. They keep the water out. Basically, that's what boats do. Uh huh. Yeah, that's what I meant.
Re: Das Boot??
Posted: Sat Aug 11, 2012 6:31 am
by chasbmw
And remember the felt seal in the clutch arm when you replace your clutch cable......
Re: Das Boot??
Posted: Sat Aug 11, 2012 11:05 am
by jagarra
Thanks Charles, yeah, another little bit to replace. I did see those on the fiche, they are located up by the handle I believe.
I used the title 'Das boot' as a play on the meaning and after all, we do try to provide subject titles that spark attention, and the part is a protective boot.
I thought Das Boot was a great movie when I first saw it.
gg
