Karcoma blues
Posted: Wed Oct 24, 2012 7:03 pm
by Unclviny
1973 R75/5:
Saturday night I was riding home and the R75/5 was running fine but when I let it idle-down it would just idle-down to nothing, I felt like it was starved for fuel.
I looked today and the right Petcock flows like it should but the left lets a drop through about every 4 seconds! (I had a school for work for the last 3 days) so today I drained the full-tank and removed the left Petcock which appears to be packed (almost) solid with tank-liner, I can't get (very much) air or water through the thing.
There are no rebuild kits in town and I need the bike saturday, luckily there is a new Petcock on the shelf at my local-BMW-dealer.
I love my Bavarian Money Waster sometimes!, the tank has been "shedding" liner for a while now so this wasn't a complete surprise.
Vince
Re: Karcoma blues
Posted: Wed Oct 24, 2012 8:03 pm
by dougie
Unclviny wrote:so this wasn't a complete surprise.
Vince
Back at the factory they would say it was your fault.
Nasty buggers.
Re: Karcoma blues
Posted: Wed Oct 24, 2012 11:12 pm
by mattcfish
Strange... My highly modified /6 will run just fine on 1 pet cock, even at full throttle.
A clogged petcock is a problem to fix, but it shouldn't effect idle if the other one is flowing.
Re: Karcoma blues
Posted: Thu Oct 25, 2012 2:21 am
One petcock isn't enough flow under certain conditions. Besides, it is risky, so why allow it. Always assure full fuel flow through both petcocks.
Re: Karcoma blues
Posted: Thu Oct 25, 2012 2:44 am
I've never experienced an issue with running on one petcock, even wot in 5th on long straights.
It's hard enough remembering to turn off one fuel tap, let alone two.
Re: Karcoma blues
Posted: Thu Oct 25, 2012 6:04 am
ME 109 wrote:I've never experienced an issue with running on one petcock, even wot in 5th on long straights.
Same here.
Unc, would some compressed air thru the tap clear it?
Re: Karcoma blues
Posted: Thu Oct 25, 2012 10:50 am
Yes Steve, that is for emergencys only, as it is temporary.
Our race bike woulnd't even run to top speed with both petcocks on and a low fuel level. The petcocks can become your main jets and that isn't good.
Re: Karcoma blues
Posted: Thu Oct 25, 2012 3:58 pm
by Unclviny
I tried clearing it with air, water and shock and the tank-liner-bits seem to be keyed in there very-well. I went to my local dealer this morning and he had them on the shelf (they are 90 degree outlets so I got both-sides), $83.00.
I have the bike sitting in the sun with both Petcocks off and the cap open, my plan is to wipe-out the inside with a curved-rod with a small towel taped on the end to get the loose-stuff off and blow the tank out with an air compressor and a blowgun.
Vince
Re: Karcoma blues
Posted: Thu Oct 25, 2012 8:01 pm
Remove the tank, insert many nuts and bolts, shake well and clean out.
Re: Karcoma blues
Posted: Thu Oct 25, 2012 8:05 pm
by dougie
Duane Ausherman wrote:Remove the tank, insert many nuts and bolts, shake well and clean out.
+1.
I also did varsol, soap and water, and sunshine after the nuts and bolts.
You could also consider POR-15, but that's a big job. (Ain't done it yet.)
