running without instrument cluster /generator light
Posted: Mon Nov 05, 2012 8:48 am
by hal
Hi,
I'm rebuilding my 90/6, losing the Pichler fairing and some more. The Pichler setup includes a square headlight and the wire nest are moved to a box where the instrument cluster normally sits, Instruments are mounted on the pichlers frame. Now, I have to sort out how to sort it all to a more original state. One of my options would be to run it without the instruments for a while till I get the mounting-bracket sorted out. I understand there is a problem with the chargin system running without the bulb? Could it be sorted with a lose bulb or even with a resistor? And how big should it be - how many watts are the bulb would answer that I guess..
Thanks!
Re: running without instrument cluster /generator light
Posted: Mon Nov 05, 2012 11:30 am
In all it's glory, Snowbum discusses this here:
http://bmwmotorcycletech.info/genlampresistor.htm
Let us know if you need to adjust your glasses! :lol:
Posted: Mon Nov 05, 2012 1:54 pm
by hal
There's a reason I seldom read heis work yes.....I'll try zooming my browser:-)
Posted: Mon Nov 05, 2012 2:13 pm
by hal
Thanks, that was very helpful!
Posted: Tue Nov 06, 2012 10:55 am
by Jean
Just a little thought so you don't run into trouble:
A resistor WILL work, but the little lamp is for YOU to SEE if the rotor is really getting current and finally, if the charging is really happening when the lamp goes out when the engine runs fast enough.
You cannot tell any of that with only a resistor.
Posted: Wed Nov 07, 2012 9:47 am
by montmil
Two of my three Airheads have been "relieved" of much OEM instrumentation. I kept the GEN bulb on-line and also installed the in-line resistor harness. Sort of a "belt and suspenders" kinda guy. And, yes, the alternator will not charge your battery as the GEN bulb is part of the charging system's 'exciter' circuit.
The GEN light is an excellent diagnostic tool for charging problems. Encourage you to keep it... somewhere.
Posted: Thu Nov 08, 2012 4:28 pm
by hal
thx, and I will, just not sure on how yet, and I guess I'll want some trips when spring comes before the answer to that pops up.
