1971 R75 Rocker arm shafts
Hi all, I am in the process (finally) of assembling my R75. Should all the pieces of the rocker arm shaft just slide on or are they press fit. When I took them apart I had to press the pieces off.
Thanks for your help
Ron
BTW Ken, I'd like to make it to the spring rally, but don't know if the timing will work
Ron
Re: 1971 R75 Rocker arm shafts
Are you using the brass bushings or needle bearings? Bushings should slide, but the bearings are pressed in.
I'm using the brass bushings which went on ok, it's the thrust bushing and shaft support thatr I'm having trouble with
Anton says they are a press fit, assuming yours are the ones without a slot and a warpy washer for end play: http://largiader.com/tech/rockers/
Thanks Tim, mine do not have the slots but do have the wavy washer. i'm wandering if I should go ahead and get the flat washer Anton mentions
Thanks for the help
Ron
Thanks for the help
Ron
I would replace the wavey with the flats
Judging from his description; if you have brass bushings in the rockers you already have the next generation of those, so I'd say go for it. They sound easier to adjust the end play than the later split block type.
sounds like the flat washers are the way to go. Guess I should be able to get them through my not so local BMW shop.
- Ken in Oklahoma
Ron Baker wrote: . . . BTW Ken, I'd like to make it to the spring rally, but don't know if the timing will work
That would be great Ron. Let's hope it works out.
Ken, I know I'm committed for the 1st weekend yopu mentioned, pretty sure the 2nd weekend is open at this point. I'll keep watching for updates
