Charging questions
Posted: Sat Jan 05, 2013 6:52 pm
Hello gentlemen,
Long time, no post.
it's been an interesting few years, had bypass surgery, got married, had a decent business that is struggling due to overall conditions, but I'm happy and I have a rebuilt heart that should last a while longer.
But anyhow, i have been trying to get the bike ('78 R100/7) on the road, added a second disc, solved the leaky undertank master cylinder issue (fingers crossed) and a few other things, but I would like some verification on my charging system diagnosis, if I may ask for help.
New battery, had the bike out last weekend and was going to take it out Monday AM when the starter sounded sluggish, horn wouldn't blow etc. Checked voltage at battery and it was down to 11.9v. Put it on the charger, and when I got back all was good. Then I decided to check the charging system.
At 4000 RPM i was getting 13.2v across the battery terminals
16.7v across the B+ to D- on the diode board and alternator, respectively
11.7v at the disconnected D+ on the voltage regulator to negative on battery
Haynes says a difference of more than 4?v and there is a problem with the diode board.
I pulled the board, most of the terminals were pretty corroded from the old leak in the M/C. Hoping that that's all it was, I cleaned them,checked the diode board (OK) and made up new leads from the alternator to the board. Made all the connections and rechecked.
@4000 RPM, 13.6 across the battery
16v across B+ to D-
12v at D+ to battery at the voltage regulator lead.
I added a test lead from the other D+ on the rear of the board, reconnected again and got 13 4v from the test lead to battery negative.
That's where I sit now as I had to go make a pickup at the airport.
i am going to connect the test lead to the VR and see how that reads and maybe improves charging voltage, I would really like to see 14+v across the battery terminals. The VR is a solid state one from Motorrad if I recall correctly.
Long time, no post.
16v across B+ to D-
