4 speed gearbox
Posted: Mon May 13, 2013 2:23 pm
I've got my gearbox on the bench while doing a rear main seal and I have a question about weather it's functioning properly. Rotating the input shaft by hand while pulling on it causes it to bind. When I push on the shaft or put pressure on it radially while turning it, things seem fine. No notchy-ness in the bearing is detected when its turned, even when it's binding. Waht is causing this?
In use things seem fine although 4th gear has a distinct wine which may just be the helical gear noise that's often talked about, I have nothing to compare it too so don't know if the sound is a clue.
Can I run this box or does it need service? Thanks.
DF
'73 R75/5
DF
'73 R75/5
