'76 R90/6 with 92K miles. I recently noticed that the indicator ramp switch had a problem when I had to fiddle with it to get the left turn signal to activate it. The right is fine...
I removed the phillips screw to take control switch cover off, blew some air in and then tried it again. Right works fine however when I try the left, and wiggle it a bit, I saw a bit of smoke drifting up. The smoke is only present when the turn signal is turned on.
In the Clymer manual it says that you can't repair anything within that white plastic cover of the control switch which houses the wiring/connections for the signals, kill switch and starter switch. The whole component has to be replaced.
Is this correct? If so, does that include the whole wiring loom that goes back to the headlight etc? I'm hoping for an easier solution.
In the meantime I guess I'll leave the turn signal switch alone and resort to hand signals.
Thanks in advance guys...
Ron
Vancouver Island BC
