I have a 76 R90\6 I am currently in the process of rejuvenating. I need to replace the missing clutch switch that is located on the clutch control lever. When I removed the old broken one I found it was not connected to any of the electrical connections in the headlight. Could someone tell me which terminals it is supposed to be connected to? Any help would be appreciated
Thanks
Rick
Clutch Switch Question
Re: Clutch Switch Question
That switch should have a brown and a brown/yellow wire. The brown joins its friends in the ground area of the little board. The brown/yellow should be similar--look also for the mark "85b" in that area. As it's a simple switch, it's probably no big deal if the wires are reversed.
Also, that switch is just there to prevent starting the bike in gear. It can be eliminated by connecting the wires together. Remember to pull in clutch lever before starting...
