I am replacing my trusty progressives that I have had forever. I've always thought they were pretty good but lately I'm looking for an improved ride. Despite backing off the pre-load so its now 'old-buick', the front end is harsh at highway speeds on the patchy roads round here. The jarring is tiresome on a long trip. I think its the compression damping as they work pretty good at soaking bumps at slower speeds.
I chose Sonic springs after reading a post by Blitz and his success with fitting gold valve emulators using these springs. viewtopic.php?f=1&t=2598 I want to fit the gold valves, but will just fit the springs for now and see what difference they make.
That's the progressive spring on the left.
The Sonic springs have a spec of 0.65kg/mm. With my daughter's help I tested them on the bathroom scales, yep, about 65kg to compress 100mm. They are a straight rate, so no progressive increase in the rate. I pulled out my old springs and also tested these on the scales. To my surprise I got exactly the same result
I've left the oil untouched (7.5wt) just checked and adjusted the level, cut spacers to 60mm length which gives 15mm preload and a laden sag of ... 60mm. A bit more than I had before. It's a rainy weekend but I hope to test it out next week on the run to the Alpine Rally.
