The battery on my airhead died. After some research, I purchased a Dry Charge Yuasa Lead-Acid Battery. I filled the battery with the acid according to the instructions and connected my BMW Advanced Battery Charging System (Programmed for BMW Gel Batteries...of course
It's been hooked up 24 hours. The green light is flashing. and the red "Charge" light is on. With the charger connected, i get a reading of ~13.85 Volts with my multimeter. When I disconnect the charger, i get a reading of about ~13.0 volts.
My question(s) are as follows (and most stem from a youtube video where the charge read 13.7 volts disconnected...albeit from a different model battery):
1. Is this an acceptable reading?
2. If yes, can i snap the fluid caps tight and install it or should i detach from the charger and retest after a set amt of time?
3. If no, could you suggest something i may be doing wrong
...I shoulda just bought a gel battery i suppose? man....electrical kills me. doesn't help that have no garage.
Thanks!
