Page 1 of 3
Battery for R75/5
Posted: Tue Aug 25, 2015 8:19 am
by slyngej
Which battery would you recommend for a R75/5.
I guess much have happened since the 70s which my manual is from.
Gel, lead-acid...?? and how many Ah would you recommend?
Re: Battery for R75/5
Posted: Tue Aug 25, 2015 8:37 am
by Texer
I use the Panasonic
https://www.amazon.com/gp/aw/s/ref=is_s ... asonic+lc-
It comes in the thin size the fits (important) my swb 1970 r75/5.
No complaints at all.
After seeing the posts, I checked again and this is an AGM after all.
Posted: Tue Aug 25, 2015 1:01 pm
by Ray from Indiana
Oddysey PC680 , they're AGM type...I have 1 going on 6 years running fine, 1 at 4 years, 1 at 3years....all good if you charge em up the right way.
Posted: Tue Aug 25, 2015 2:27 pm
AGM's are much less finicky than gels. Thus, I either go with the cheapest wet cell I can find, or I go with an Odyssey. I've given up on gels.
For something prone to falling over (GS's, for instance), I never go wet cell. My Oilhead has an Odyssey. My Suzuki DRZ400 has a lithium - which also is super light, but I wouldn't spend for one of those for a normal street bike. Where I live there's a long winter, so the fact that both lithium's and AGM's will better stand sitting without being used for long periods is important to me. If I lived somewhere with a year-long riding season, I'd be a lot more likely to run a conventional wet-cell in the Oilhead. My /2 held a wet-cell, but that was mostly because it just seemed wrong to put anything more modern in there.
Posted: Tue Aug 25, 2015 4:24 pm
Deka etx16l. Excellent. Smaller than stock, agm, cheaper than Odyssey.
Posted: Wed Aug 26, 2015 5:25 am
by slyngej
Thanks alot! How many Ah would you recommend?
Posted: Wed Aug 26, 2015 8:50 am
by pkboxer
http://www.batterymart.com/p-yix-30l-ag ... 0s-battery
If you have the LWB - larger battery tray
More cranking than most.
Cheaper
No maintenance
Made in USA
Think it's the house brand for the factory that makes Yuasa
Posted: Wed Aug 26, 2015 9:49 am
slyngej wrote:Thanks alot! How many Ah would you recommend?
The Deka specs: 12 volt 325cca 19ah
Sealed AGM Deep Cycle
Left Hand +, YB16C-B
7.7kg
175 x 100 x 155mm
Posted: Thu Aug 27, 2015 4:40 am
by chasbmw
When thinking about batteries and charging systems it's worthwhile to think about the consumption side of the equation.
An early airhead with a worn and Weak starter motor will suck the life out of most batteries on a cold start and the battery won't have time to recover if used on short trips. it can worthwhile to think about a new starter that will kick the engine into life much more quickly and really reduce drain on the battery at startup.
Posted: Thu Sep 03, 2015 9:28 am
by slyngej
My motorcycle had a hard time recharging the gel battery ive used. Which kind of battery i best for short trips, are some batteries easier for the bike to charge?
