Horns stopped working
CafeRS
Post by CafeRS »
It was a beautiful day in the New York today, so I gave my 81RS a good cleaning. I took the horns off, but when I put them back on, they did not work. I know the horns are fine. Is there a fuse for the horn? :?:
Thanx Much
James
Re: Horns stopped working
Yes. The horns use the same fuse that power the voltmeter, turn signal relay, and probably something else. Be sure your grounds are fine...the horns should ground at the horn attachment. Always check the last area you were working in.
