Help - '78 Fork Rebuild
Posted: Sun Aug 14, 2016 11:19 pm
I went to change the fork oil in a recently purchased '78 R100/7 and when I went to drain it all that came out was a black ooze with grit in it, so I had to completely disassemble.
When I finally got both legs off the bike and opened things up it was apparent they hadn't been serviced since it was purchased new... the bushings were completely GONE, they had been pulverized into a fine grit and emulsified in the fork oil to create an interesting substance that had caked onto the dampening rod and all the internal parts like shotcrete. Soaking in turpentine for 2 days did nothing. I finally had to take them and have them commercially blasted with a high pressure steam gun to get all the crap out.
I'm now trying to reassemble them and the Clymers manual isn't as detail oriented as I might like. Several questions I have:
1. Do I have this small bushing in the right place?
2. Which is the proper orientation for the large bushing?
and
3. Do I have all the parts lined up in the correct order?
4. What the heck are these 4 extra rings for that came with my rebuild kit? When I disassembled mine these were definately not inside the fork tubes, the shocks or the dampening rod assembly.
5. The two washers on the right (above) were sitting on top of the fork springs, however they don't show up in the Clymers manual... Toss em?
6. Is the gasket (#40 listed below on the Clymer page) referring to the copper piece on the bottom of the dampening rod assembly or is this another pulverized part that I'll need to order.
and
