New Camshaft 1977 R100 swap?
Posted: Tue Sep 13, 2016 7:33 am
by bigfella
Hi Guys,
The camshaft on my project bike (R100/7) has been modified (read butchered) by having the weights welded onto the end as the thread has been broken off.
Replacement cams appear to be made of rocking horse poo so I ask if I can replace with a newer camshaft even if that means using a different gear and ignition system - I was going electronic anyway.
cheers, Sam T
Re: New Camshaft 1977 R100 swap?
Posted: Tue Sep 13, 2016 8:23 am
I know that this is of no interest to you and your situation, but someone else might need this info.
It was common for ham fisted idiot mechanics to break off the threaded cam tip. So much so that an after market kit to fix it easily has been available for at least 25 years. It is simple to fix with the kit.
Posted: Mon Oct 03, 2016 4:26 am
by Zombie Master
I've fixed them by filing the end of the camshaft flat, then drilling and taping for a machine screw.
Posted: Mon Oct 03, 2016 5:38 am
by Foxy
Hi Sam
I don't know much about cams, but if you are thinking of electronic ignition, the Alpha Classic is a great improvement over the original system. No more fiddling with points and worrying about mechanical advance mechanism. The green Dyna Coil is worth considering as well. I have no affiliation with anyone who sells these items.
Cheers
Harry
