Master Cylinder
woodly1069
Master Cylinder
Post by woodly1069 »
Can anyone tell me when BMW started mounting the master cylinder on the handlebars? Thanks!
Tim
Re: Master Cylinder
woodly1069 wrote:Can anyone tell me when BMW started mounting the master cylinder on the handlebars? Thanks!
Tim
From the 1981 models on...after September 1980.
http://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx
Trying to cross reference these dates from the usual parts fiche, looking under "brakes" the realoem and max fiche show the under tank setup, to 9/80.
You need to look at the "steering" section.
woodly1069
Re: Master Cylinder
fantastic! Thanks for the quick reply! The reason I ask is because I am chaning the original front end to something with a Nissin brake assembly and need to be able to activate it.
I have a 1978 R80 with the cable only coming out of the handlebar housing, is there a way to add this master cylinder to the existing assembly or do I just need to find the whole assembly with the master cylinder on the bars and eliminate the under tank master cylinder? Any advice is appreciated!
Tim
Re: Master Cylinder
woodly1069 wrote:.... I just need to find the whole assembly with the master cylinder on the bars and eliminate the under tank master cylinder.
Yep. It's not something that's never been done before. Usually best to source a 13mm mc from a monolever.
http://www.advrider.com/forums/showthre ... 179&page=5
woodly1069
Re: Master Cylinder
Great! thanks for your help Steve!
Norm T R100T R1150RT
Re: Master Cylinder
Post by Norm T R100T R1150RT »
Norm Taylor
1980 R100T Airhead
2002 R1150RT Oilhead
1950 HD Panhead
Southern Maryland, USA
2003 K1200 GT
