I'm afraid not, Abstrese, that is unless you've done the research on the old master cylinder ratio to caliper piston(s) area compared to the ratio with your envisioned solution (same master cylinder brand and style). All other factors being equal it's all about that ratio, both for braking power and feel.Abstruse1 wrote:. . .With this setup, I think I'd need about a 12mm MC (currently have 14mm).
But I have a pair of R100 or somesuch forks on the way from the 'Bay, so I'll have the easy opportunity to fit a better caliper, maybe a 4-pot, in which case the 14mm may be better.
But then you may be fully aware of that and are planning to take such into account.
