Rear mastercylinder
Sunbeem
Re: Rear mastercylinder
Post by Sunbeem »
I tried to rebuild the rear master cylinder on my '78 RS, but there seemed no way to remove the circlip as it sat neatly in a groove in the bore, with absolutely no way of getting a purchase on it. Eventually I assumed it was non-repairable ...
was I wrong ?
Sunbeem.
One day more -- one day less.
Motorhead
Post by Motorhead »
Sunbeem wrote:I tried to rebuild the rear master cylinder on my '78 RS, but there seemed no way to remove the circlip as it sat neatly in a groove in the bore, with absolutely no way of getting a purchase on it. Eventually I assumed it was non-repairable ...
was I wrong ?
Sunbeem.
I found to remove the pack I needed to use a pin punch though the line fitting
when I removed my pack I found the bore was gone from debris getting through the rubber cover
Motorhead
Post by Motorhead »
I decided to remove all Hyd systems from Red and return to drum
I have most all the drum stuff, I need but need to sell my Snowflakes and 40mm calipers and brembo rear calipera nd related parts let me know your needs
