Shades wrote: ↑Tue Nov 07, 2017 5:42 am
I found that keeping the oil at half and re-routing the crankcase breather out through the air box and up under the seat with a small filter at the end helped a lot ! Almost did the job.
This is good news indeed. But I'm still interested to know what you found when you removed the 2 small covers just to the right of the starter motor. Did you find the "oil return divot" full of oil ? Did your bike have the breather disc, and was the disc chipped or cracked ? Did you convert to the reed breather valve ?
Either the valve guides or oil rings on the left side is bad. I really think the heads are in good shape, as far as I know they have run less than 5000km since they where converted to led free and the seats and valves looked perfect ! What is the best way to check the guides ?
When the valve seats were converted, the
guides would most certainly need to pass a mandatory inspection because the mandrel that supports the valve seat cutter is completely supported by the guide. That is to say, the valve seat MUST be cut concentric to the valve guide stem, and the only way to do that is locate the cutter on the valve guide's axial center. Replacing the valve seats is a HIGHLY technical task requiring great experience and expensive tooling. If the guides were loose or out of spec, then the valve seat cutter would not maintain its "center" and the job would need to be aborted. Therefore, I would assume that nothing is wrong with your valve guides.
You keep making this claim that the valve guides are some how "bad" or out of spec, despite oil found in the intake track and defying all logic. Do you know something that you are not telling us ?
The engine smokes on start up (I always park it on the center stand) and on hard acceleration.
1) With the amount of oil puddling in the intake tube that your photos showed,
I'd be very surprised if your engine didn't smoke on start up !! It may take
several weeks of regular running to remove all the oil from the intake. With your new external breather hose, I'd expect less and less oil smoke on each subsequent ride.
2) My BMW also "smokes" on start up, but this is condensation (water vapor) being released through the exhaust as a normal by-product of combustion with the enriched mixture due to the choke being turned ON. Are you confusing the white smoke of burning engine oil with the white cloud caused by water vapor ??
Hope this helps.
