Toaster Gas Tank Seal Replacement
MikeGeee
Post by MikeGeee »
Hi All,
So I share my garage with my girlfriend and she's constantly complaining about the mild gasoline aroma coming from my 1972 R75/5 Toaster.
I purchased a new gasket, a new rivet and a new washer (part numbers 16111230603, 07119904207, 07119944651 respectively). These are all the parts I can image would need to be replaced. But I can't figure out how to get the old gasket off. I'm not familiar with rivets. I've never worked with them before. Should I drill out the old old? Is there some trick?
I'd love some expert advice on this.
Thanks as always,
Michael
ps, photo of new parts attached
1972 BMW R75/5 Toaster
1976 Honda CB200t
1948 Harley Davidson WL45
Re: Toaster Gas Tank Seal Replacement
Duane wrote:The cap has a gasket under it to seal fuel. A rivet is pressed into the cap to hold the parts in. It is hard to remove. Some gently grind flats on the sides so that pliers can get a good hold on it and rotate while pulling it out. Some owners tap the hole and install a screw. That makes it easy to repair in the future. I suggest using Locktite on that screw. If it falls into the tank, it is hard to remove again.
George Ryals
Post by George Ryals »
The mild gassey smell may not be from the gas cap seal leak. it could be from a weepy fuel line.
Smile it's contagious!
'85 R80RT wreck for parts
George Ryals wrote: Sat Apr 28, 2018 9:35 am The mild gassey smell may not be from the gas cap seal leak. it could be from a weepy fuel line.
Or a bad float chamber gasket.
Or a leaky tank seam. Wich is common.
Wobbly
Post by Wobbly »
Besides all those comments on sources, the fuel cap has an open breather vent. Vapors would be escaping from the breather as well.
