I've owned my first airhead for a month now, it's a 1985 R80 Monolever. Really nice bike and already've got my hands dirty a number of times
A week ago it misfired a few times while driving, it was a warm day and the tacho needle went to zero when the problem occurred. Finally wouldn't run anymore, would start but die instantly. After some measuring thought it was the coil as the primary had a 4,7 ohm resistance. Replaced that with 3,0 ohm Harley unit, didn't help. Found a bad contact at the ICU connector, fixed that but no help. After more measuring I came to a conclusion it must be the ICU.
So, with the original Bosch 0 227 100 103 ICU it will start, but dies instantly. I've bought three ICU's so far, with the first one it wouldn't start at all, with the other two it will start, but the timing is retarded so much I cant get it adjusted and the bike wont rev more than 1500. Struggling to idle too.
Where can I find a working ICU? 153€ at the BMW dealer...
Could it be a problem with the bean can? I replaced the advance springs in that, that solved the high idle issue. The hall sensor tests fine, triggers twice per revolution with around 90 degree zone where it is switched on. I could drill a new pin hole and rotate the cog on the ATU, but that doesn't sound too tempting.
