1975 R60/6 Ignition System Condensor Installation
bk1977
Post by bk1977 »
Hello,
I am replacing the Ignition system condensor and points on my 1975 R60/6.
When installing the new condensor [12 11 1 351 564], I am seeing that both electrical connectors on the condensor appear to be identical. Is there a specific connection required when attaching the electrical leads upon installation? I am not seeing any markings for polarity or specific connection on the condensor itself.
Many thanks,
Ben
boxme60
Re: 1975 R60/6 Ignition System Condensor Installation
Post by boxme60 »
Did you progress any further on that point?
bk1977
Post by bk1977 »
Hello,
I did make some progress, I spoke to the team at Euro MotoElectric where I purchased the points and condensor from. Here was there response to the question in the initial post above:
"Thank you for your purchase!
The condenser has no polarity – the outer case is grounded and the spade connectors are both positive.
Hope that helps?"
Condensor and points are installed and so far so good on startup.
Thanks for asking,
Ben
