Rear Wheel tophat shim
Re: Rear Wheel tophat shim
ME 109 wrote: Thu Apr 04, 2019 2:27 am 2mm is nothing regarding alignment. At present with the bigger top hat you have full contact. If you look at your fd splines you'll see a step in the splines from normal wear. That's ok.
With the big top hat left in place, there will be no difference in alignment between the two tyre sizes.
As mentioned it's just not a good mechanical situation to have all the torque going through a small contact area.
Most likely both the fd and wheel spline will yield until full contact is restored.
Good point! I would like to get back full contact with the rear brake shoes. The rear brake works fine as it is but better is better. You can see the two steps if you look closely.
IMGP0072 copy.JPG (123.62 KiB) Viewed 1189 times
Slight side track on this... Regarding pictures, as in ZM's picture above...how can it be viewed zoomed in for more detail? I see at the bottom is says "IMG.... Viewed 2 times". How was it viewed? I can't click on the picture to do anything. Is there something wrong on my end?
Now back to the regular discussions!
I saved the picture to my desktop and was then able to zoom in.
Yeah, have done that sort of thing. Still doesn't explain why the figure has been "viewed X times".
Thanks...Kurt in S.A.
Kurt in S.A. wrote: Sat Apr 13, 2019 11:11 am Yeah, have done that sort of thing. Still doesn't explain why the figure has been "viewed X times".
I guess that is how many have seen it?
In order to upload the image to the forum I had to compress the image...a lot.
As I write this, it says viewed 10 times. So, everyone who comes to this thread "sees" it? Usually being viewed means it was clicked on so it could be expanded in another window which allows for zooming, scrolling around, etc. I don't get any of that action.
Makes sense, I'll leave the spacer as is. The ridge left on my brake shoes; does that need an adjustment. My rear brake works OK, I just noticed that it doesn't use the entire surface. :ugeek:
