Riding along today, a slight whirring noise then when accelerating from 80-100kph a grating noise, no increased road speed and elevated rpm. Clutch in, backed off and cruised to the verge. Gear change felt fine, engine felt fine, clutch lever all good. Headed 5km home, same happened again so I left it in 2nd. Got home, drained the trans. Usual collection of stuff on the magnet. Swapped bikes and headed back for work.
So home from work. Too late to fire it up and run it with the rear wheel in the air to assess for noises. I had a good look at the trans oil however, and found this.
I'm guessing it's the transmission.
