Cleaning Practices?
Trade secret
kmisterk wrote: Thu May 06, 2021 10:50 pm What process do you use for cleaning?
If I told you I would have to kill you :o
kmisterk
Re: Trade secret
Post by kmisterk »
gspd wrote: Fri May 07, 2021 4:49 pm
LOL Fine.
How about...
What processes *don't* you use? :D
Boxer Biker Log
Re: Trade secret
kmisterk wrote: Fri May 07, 2021 7:36 pm LOL Fine.
How about...
pressure washer
Re: Cleaning Practices?
gspd wrote: Fri May 07, 2021 7:58 am
Rob Frankham wrote: Fri May 07, 2021 4:44 am A pressure washer is fine as long as you keep the jet away from wheel bearings and other 'vulnerable' areas... there aren't many on an airhead. What it will do, however, is reveal any areas where the paint is (was) loose and tend to remove any protective coatings you have applied.
A pressure washer is fine as long as you keep the jet away from your entire bike and clean your driveway with it. :o
+1 :|
kmisterk
Post by kmisterk »
Zombie Master wrote: Fri May 07, 2021 7:56 pm
+1 :|
Lol. Noted.
gspd wrote: Fri May 07, 2021 7:56 pm
How about...
pressure washer
All I needed to hear :D
Boxer Biker Log
If I knew how to post a pic these days I'd show you two how good a pressure washer works in professional hands.
I haven't killed anything with a pressure washer on the same RS in 27 years. (I have other ways to break shit.)
Except I blew the bullet holes off my tank with the pressure washer in one fell swoop. I was a bit annoyed about that.
Pressure washer bits to avoid as mentioned include the wheel bearings but also the speedo cable at the trans, the handlebar controls and the instruments.
A mate found his 81 RS would only start and run intermittently after a pressure wash. It'd die after ~ 1km. That was a coil problem in the end.
My RS doesn't do the kms it used to anymore so it doesn't need as much attention. It gets a decent wash when I do an oil & filter change. I tend to remove the exhaust system to clean and polish, that gives access for cleaning some other bits and pieces. I just use an auto cleaning detergent or truck wash...depends what's on sale when I need it.
When finished, the paint gets a good going over with a quality polish. I find that allows me to give the bike a light wash occasionally without spending much more time on it.
https://juicepolishes.com.au/product/speed-wax/
The powdercoated snowflake wheels get a good wipe down when they're off for tyre changes. They usually need a little degrease spray, then I spray some detergent over them to sit for a while then wipe off.
PXL_20210426_220513063 copy.jpg (770.88 KiB) Viewed 1107 times
I just let mine stay out in the rain....it rains a lot on Vancouver Island. :|
kmisterk
Post by kmisterk »
ME 109 wrote: Sat May 08, 2021 2:57 am If I knew how to post a pic these days I'd show you two how good a pressure washer works in professional hands.
If you're serious about wanting to know how to post pics in today's forum spaces, I'd be happy to help you.
SteveD wrote: Sat May 08, 2021 4:31 am Pressure washer bits to avoid as mentioned include the wheel bearings but also the speedo cable at the trans, the handlebar controls and the instruments.
I think for now I'll stick to non-pressure-washer methods just so I don't mess anything up that I don't know how to fix.
SteveD wrote: Sat May 08, 2021 4:31 am I just use an auto cleaning detergent or truck wash...depends what's on sale when I need it.
Wow, very nice looking bike, SteveD. Makes me definitely want to put some solid effort soon into getting the grime off the bike and making it look nice once more.
There's a gnarly dent on the right side of the gas tank. I'd like to get that removed, but I don't have the tools to get that going.
Zombie Master wrote: Sat May 08, 2021 12:22 pm
Ayyyyye you're not too far from me, then. I was up in the San Juan Islands a couple of weekends back. Not on the bike, but the wife and I were on a bit of a mini-vacation. Was nice out there.
Also, very pretty bike.
Boxer Biker Log
"Ayyyyye you're not too far from me, then. I was up in the San Juan Islands a couple of weekends back. Not on the bike, but the wife and I were on a bit of a mini-vacation. Was nice out there.
Also, very pretty bike."
When the plague has receded let's do a meet up. I often come over to Port Angeles. Canada has no good Mexican food.
