How Long to Gaskets Last
- Jeff in W.C.
I went through my stash of parts, and noticed I had purchased spare gaskets (e.g. timing cover, oil pan, etc.), shaft seals, pushrod tub seals, various o-rings, etc. How long do these last? They've been in my garage, which can get very hot (105+) several times a year. The majority of these were most likely purchased ten years ago--give or take a few years.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
1988 R100 RT
2018 R1200 GS
Re: How Long to Gaskets Last
Just about forever if they're kept flat, dry and undamaged...
- Jeff in W.C.
Rob, thanks for your response.
Jeff in W.C.
1988 R100 RT
2018 R1200 GS
1988 R100 RT
2018 R1200 GS
I wonder what the shelf life of rubber is? eg the push rod seals.
- Zombie Master
Again, with most synthetic rubbers, provided they're kept in original packaging and kept away from chemicals and sunight, they'll last a very long time without ill effects. It's heat UV and chemicals that cause 'rubbers' to detetiorate... that and physical damage.
Not sure I'd trust the viability of gaskets/seals stored that way for that long. IMO not worth the consequences or hassles to have to do a job a second time.
