Luftmeister Auxiliary Fuel Tanks on eBay
vanzen
Re: Luftmeister Auxiliary Fuel Tanks on eBay
Post by vanzen »
A good link in that auction, too, regarding care and feeding of those things.
Deleted User 61
Post by Deleted User 61 »
vanzen@rockerboxer.com wrote:A good link in that auction, too, regarding care and feeding of those things.
Wow - I had never heard of them being made for Type-248's. (Not that they did)
Learn a new 30 year-old rumor every day! (Well, not every day.)
dwerbil
Moderator
Post by dwerbil »
All good except I'd totally would not use his hook-up directions, you'd end up with a whopping tonnage of possible leak points using all those tee's. My set up uses only two tees...
Main tank left petcock line go straight to the upper inlets of the left Luft tank; same for the right. Each bottom Luft petcock lines go directly to it's corresponding carb inlet. INBETWEEN the bottom lines, put in two tee's to make the cross-over.
And that's all the tanks need for hook up. The above has about half the fuel line connections as Snowbums.
Click for pics
Randy in Round Rock
dwerbil
Moderator
Post by dwerbil »
Sold for 200 smackers. Has the high price ebay days for the Lufties run out of gas? It looks like it did at least for this seller's set.
Click for pics
Randy in Round Rock
