Electrical Gremlin.....
Single & twin cylinder model BMW Airhead specific discussions
jlibby
Post by jlibby »
Have developed a quirky electrical issue over the winter that makes no sense to me. All electrics worked fine when I put it away last fall. Here goes - 1965 R60. When my headlight is off, but key pushed in for starting, my Hella blinkers work fine and bright. When the key is turned to either headlight on, or parking light on, the blinkers stop working. Makes no difference if the motor is running as I get same result. Could it be in the switch? I pulled it apart and all wires connected properly. The battery is charged. Something I'm not thinking of?
Re: Electrical Gremlin.....
Did your blinkers ever work "correctly" before, that is with the key in any position? Vech has instructions for properly wiring the barend signals. Is yours wired like this?
http://www.benchmarkworks.com/articles/ ... ignal.html
macdaddy
Post by macdaddy »
Did you "snug" up the lugs in the headlight? and a little "contact OL" from wurth is magic stuff! gets rid of the electron droppings!!
macdaddy wrote:Did you "snug" up the lugs in the headlight? and a little "contact OL" from wurth is magic stuff! gets rid of the electron droppings!!
Have you been finding electron droppings in your nacelle?
macdaddy
Post by macdaddy »
Yes! messy little buggers!
