That actually makes some sense...Motorhead wrote:GUYS GUYS its the fuel........................ it lost it balls
R100RS top speed.
Re: R100RS top speed.
...test run this weekend showed an indicated 115/GPS 111, 10mph tailwind, may have had a few more clicks left in her.
Never did reach redline, more like maybe 6500rpm in 5th.
Are you sitting up or crouching behind the screen. I don't recall the numbers, but an early test I read a while back gave the top speed with the rider seated normally as being achieved in 4th gear, and a bit slower than what was achieved in top with the rider crouched behind the screen.
Mike
Mike
...semi crouch but no chin to the tank if that's whatya mean...not in a land speed record pose.
Need to put on your bathing suit...Rapid Dog wrote:...semi crouch but no chin to the tank if that's whatya mean...not in a land speed record pose.
Major Softie wrote:Need to put on your bathing suit...Rapid Dog wrote:...semi crouch but no chin to the tank if that's whatya mean...not in a land speed record pose.
