Dual-plugged '78 squishban heads
Stock Nikasil cylinders an pistons
O.K., so it appears though the bike runs fine and dandy, my lack of top-end and overall softness of the motor (oh my lack of knowledge about post 80's bikes!) is due too the low compression flat top pistons.
I know, I know, the heads don't match but that's what I got.
Recommendations to me to bump up the motor is to find some 9.5-1 hi compression pistons.
My questions is what to look for best bang for the buck that I can bolt on and use.
I googled around and found this which helps me visually: http://moragafalconers.org/bmw_pistons/index.htm
I can pick up a complete 1978 top-end with 40mm dual-plugged heads and 12-1 pistons locally, but I'd like to stay with my 38mm exhaust and my Nik cylinders if possible. My heads are new rebuilds as well.
So what does Mr. Vanzen or others recommend I do here? Like, what would be a good choice of slugs only?
