I have started adding fluids to the bike on the work stand. It is a 1983 R100 that I am putting an 'S' fairing on, making it like an R100CS with minor deviations from stock cosmetics. The fork, which I prepared with the greatest of care, have leaked out their fluid. That is, at least from the right fork leg. Is there a seal that I forgot to put in there? I'm going to cry if I have to take the fork off at this late stage to perform more work on it.
Is there a procedure to seal up the bottom of the fork leg?
Fork leg leaks
Re: Fork leg leaks
If your forks are the same as my 81 forks which I think they are, there are two holes in the bottom of the slider that the fluid can come out of.
The little 4mm hex head screw with a copper washer, and the main retaining bolt with a copper washer as well I think??
I'm not aware of any procedure other than screw the bolts up.
Check those washers Chuey.
Re: Fork leg leaks
ME109, that was it. Thanks. The sealing rings were there but it was almost two years ago that I dialed in the fork and when I put it back together I left the large and small bolts in the bottom untightened. Why did I do that? It was a bad idea and I hope I've learned from it. A glance at the bottom of the fork was not enough to see that they had not been tightened.
Thanks again. That's all it took.
Re: Fork leg leaks
Sometimes, installing bolts but not tightening them until you are sure of everything, is desireable. Especially if you don't want to waste crush washers. But I learned (the hard way) to make a list, otherwise, as time passes and you do other things, you will forget.Chuey wrote:ME109, that was it. Thanks. The sealing rings were there but it was almost two years ago that I dialed in the fork and when I put it back together I left the large and small bolts in the bottom untightened. Why did I do that? It was a bad idea and I hope I've learned from it. A glance at the bottom of the fork was not enough to see that they had not been tightened.
Re: Fork leg leaks
Sorry Jeff - can't remember.ME 109 wrote:Forget what?dougie wrote: you will forget.
Re: Fork leg leaks
LOL, it is so nice to hear that I am not alone in this.
The other day I was at a local coin shop. I know the folks and always chat a bit. I had taken in some silver dollars for an informal appraisal. I walked out and left the bag on the counter. I called back a couple of hours later and when she heard my name, said, "Yes, we found your dollars and they are waiting for you." I could hear her pride along with "you are an idiot"
I just had to have some fun with this. I went back to retrieve my bag. Of course she has this very friendly, but smug look. I approached the guy and said something like this. "It would appear that I forgot my bag, but the truth is that I just wanted an excuse to come back and see Dolores." She has a family etc, but is a super person and loads of fun. She always has a smile for me as I flirt with her. Of course I said this loud enough so that she could hear it.
His answer was "Of course, I don't blame you one bit."
I just hate it when I walk out and leave $1000+ of goods on the counter.
I am not alone.
I am not alone.
Re: Fork leg leaks
Gear lube in the transmission?ME 109 wrote:Forget what?dougie wrote: you will forget.
Re: Fork leg leaks
I am here to teach.Major Softie wrote:Gear lube in the transmission?ME 109 wrote:Forget what?dougie wrote: you will forget.
