R100RS riders. Neck pain.
Re: R100RS riders. Neck pain.
She'llbe wrote:Steve, You can't fix aging. Get an RT.
Harsh She'llbe, harsh! :shock:
You might be right though :lol: but an RT iootq :roll:
dougie
Post by dougie »
teo wrote:I finally gave up on my "S" bars and put F-650 bars on my R75/6. Teo
But will they fit with an RS fairing?
I believe that is what Steve needs.
lrz
Post by lrz »
Having just returned from a ride, I can say w/ certainty it's primarily my left hand more so the pinky-ring-middle, same but to a lesser extent in the right. This after only 10mi or so. Frankly, I'm always glad to dismount the RS.
Currently thinking bar-backs may be worth a try.
Post by Garnet »
lrz wrote:Having just returned from a ride, I can say w/ certainty it's primarily my left hand more so the pinky-ring-middle, same but to a lesser extent in the right. This after only 10mi or so. Frankly, I'm always glad to dismount the RS.
What about something like this: http://www.motoren-israel.com/product_i ... -25mm.html That will raise the bars about an inch.
lrz
Post by lrz »
I just wonder if "up" is enough; feels like both up & back might be best.
My K75 had the same numbing effect, which is one reason I sold it. I did switch bars on that to no avail, so I know swapping those style bars onto the RS will not help me out.
Deleted User 287
Post by Deleted User 287 »
lrz wrote:I just wonder if "up" is enough; feels like both up & back might be best.
These set-backs look generic enough to work.
http://www.ascycles.com/detail.aspx?ID=48306
dougie
Post by dougie »
I mentioned it earlier, but have you given any thought to an S faing with S bars? I know it's a big job.
http://www.sideroadcycles.com/ImportedM ... raBMW.html (Part# C20)
Compare those measurements with your RS bars or K75S bars. That's what I did.
S fairing / S bars
RS fairing / K75S bars
I had a comeoffence about 3 years back, where I low sided at 80kph on my right side and clobbered the right side of my helmet against the asphalt, rolled a few times and went over the edge of the road, about 10 metres down into scrub. I was ok, managed to climb back up, fix the bike etc etc.... However I'm now suspicious I may have tweeked something at the time, stretching the left side of my neck and wonder if that's what is surfacing now?
Removing the RS fairing isn't an option for me...unless I choose to replace it with another one! It's too good. The bars ontheotherhand might be a worthy consideration, as might a cautious manip of the neck.
Post by Garnet »
Your helmet seems to have done it's job. :geek:
Post by Chuey »
Oh, he would have just lost some hair, (and probably a life). Oh my!
