British R1200GS contingent @ Yellowstone
Deleted User 287
Re: British R1200GS contingent @ Yellowstone
Post by Deleted User 287 »
Chuey wrote:I got the idea when discussing lions with a customer at the shop. He said he was watching a nature show and a lion was chasing a skunk. The skunk stopped and sprayed and the lion took off. Feel free to build up one of these things if you'd like.
Dead skunk on the road is one of the few real thrills I have these days. :(
I breath that shit deep!
Chuey wrote:It would employ aquarium tubing and use it to route bear spray from the front where you'd have a panic button type release and then shoot the spray downward across your back.
Difficult for an Aussie to work this out Chuey.
You're worried about a cat, but not worried about getting spray from a bear.
Unless you meant 'beer spray'? That, I can relate to.
Post by Chuey »
"Bear spray" is some very potent cayenne pepper based spray that really irritates mucous membranes in mammals.
Beer spray is also annoying. It should not be sprayed in my opinion. It would not be likely to drive away bears or lions. In all fairness, it will, however, be likely to drive away pussy. :)
Chuey.............hoping we all read enough of the other threads that the pussy reference works.
Chuey wrote:"Bear spray" is some very potent cayenne pepper based spray that really irritates mucous membranes in mammals.
I don't miss much reference wise.
Your panic button might best be hooked up to your jaw (scream activated) 'cause I think pussy will be on your back before you know anything about it! :shock:
Post by Chuey »
Agreed. That is, that you wouldn't have warning. My idea is not a preventative one but a defensive one. I would think that if you had a button about two or three inches in diameter on your chest, you could hit it with one or the other hand during an attack by a mountain lion. Less desirable, but still a possible discharge of pepper spray would be if you hit the ground on your front side. I'm still convinced that it would be pretty darn good to have in an attack.
Deleted User 287
Chuey wrote: Agreed. That is, that you wouldn't have warning. My idea is not a preventative one but a defensive one. I would think that if you had a button about two or three inches in diameter on your chest, you could hit it with one or the other hand during an attack by a mountain lion. Less desirable, but still a possible discharge of pepper spray would be if you hit the ground on your front side. I'm still convinced that it would be pretty darn good to have in an attack.
Like this?
(it is an advertisement for an office supply store)
