How do you post big pictures like this?
Nice bike. I love the seat and wheels. Where is your battery? Lithium Iron?
mattefish, one way to post a picture here like beemersanducs did, is when you're posting a reply. Just look below the message body to a couple of tabs. One is named "Upload Attachment". Just follow the instructions. It's as simple as that.
The other way is the have your photo hosted somewhere else on the web and just link to it using the forum imagine code.
Click for pics
Randy in Round Rock
I put a Briel oil cooler on my '74 R75 back in 1980. It has more than 100K miles on it now. There is no leakage from the double gaskets. I modified the centerstand dropping the upper cross piece 3 inches or so to clear the extension. There is another quart of oil in the crankase but I'm not so sure the "cooling tubes" do all that much. I ran a temp gauge for a while and notice no real difference from the standard. I bought it because it seemed to be the wonderful, caring thing to do for your baby at the time ... and I was younger os daring then too.
I have given up on the Mac extended sump, it cost me WAY too much ground clearance and I'm not going to modify the Centerstand (I tried Dremelling the fins down on the rear of the sumpp but it stil fouls the stand). The factory sump is going back on!
When I do that it says my file is too big, max size is only 256 KiB. I just tried to upload a plain old photo image, no fancy high resolution dpi etc. What am I missing?
Let's try this one of my wife...That worked. For some reason files on my home computer are much larger than the same files I've downloaded to my work computer.
OK, something more on topic. I've always had a Mac style pan. Works great, does not touch the stand.
My bike right.jpg (84.51 KiB) Viewed 2347 times
My bike left.jpg (75.56 KiB) Viewed 2347 times
That worked....hmmm.
