Another suggestion...
http://robfrankham.co.uk/bike/ezclutch_page.htm
air head hydraulic clutch?
Re: air head hydraulic clutch?
Pretty neat design. Best part is that the clutch cable remains unaltered. Looks pretty easy to make, my concern is how is the free play maintained (kept from rattling) when the clutch is released. think the addition of a spring is needed?
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
Something to keep in mind...
The clutch cable is made of 1 X 19 wire, meaning 19 wires of 1 filament each - 1 center wire surrounded by 6 wires surrounded by 12 wires. This kind of wire is not meant to bend around pulleys. That kind of wire is 7 X 19 - 19 wires of 7 filaments each. Each filament is much finer in this type of wire, allowing it to bend easier without breaking filaments.
FWIW
FWIW
The answer from Craig at Bench Mark Works regarding fitting the Easy Clutch to later airheads...
I'd still like to see if it could be done.Sorry but changes in the frame design which cut down the space available makes it impossible to use or fit on anything past 1983.
- George Ryals
jagarra, the spring under the lever on the back of the trans will hold the slack out of the cable.
Smile it's contagious!
'85 R80RT wreck for parts
