I just chopped through all the spokes on my front wheel with a grinder.
Bearing caps screwed off easily (phew),
bearings are showing some slight wear,
as I have never cleaned or greased them in 70 thousand kms they have done OK.
Then I cooked the hub on my Trangia camping stove,
its perfect, sits in there like a cooking pot!
The outer races fell out with a tap.
Now to get the hub to the sandblasters.
I'll try and get a before and after pic.
Later
Mal
Expresso front wheel rebuild
Re: Expresso front wheel rebuild
use a soda blaster!!! my BMW guru showed me the error of ways to use many other means of blasting!!!
From the desk of the
Mt. Nardi Yacht Club
PO BOX 95
Nimbin, NSW
Australia 2480
02-6689-1234
PO BOX 95
Nimbin, NSW
Australia 2480
02-6689-1234
Hi She'llbe, How ya doing?
tried Soda-blast'n the rear hub,
it won't shift nothing but paint!
I've read the stories about grit impregnating alloy and such and reckon its fooey.
Dismantled and blasted my own heads and barrels and engine covers and fork lowers about ten years back.
No different than riding down a dusty road.
Patient and very thorough cleaning stages is all ya need.
Mind you I'd prefer wet blasting but no one does that around here
cheers
Mal
cheers
Mal
Hey Mal, if ya don't get the spokes back in, yer cood always concrete the hub in place.
Those rims make fer mighty fine boxing.
Speaking of wheels, I straightened out a front wheel that I recently got from Germany.
I used a computer aided system I found in the shed.
My old computer tower was just the right height to rest a screwdriver on to use as a dial indicator.
- Airbear
Crikey Jeff, that's gettin' a bit bloody technical. Whad'll people think?ME 109 wrote: Speaking of wheels, I straightened out a front wheel that I recently got from Germany.
Gidday Mal. Glad to see you taking an interest again. Speaking of proper procedure and wheel bearings, I've just epoxied the outer race back into Brunhilde's rear hub. It was good for about 8000kms last time I did it. I suppose I'll eventually get around to getting it sleeved, but it sure is nice to be back on the road again. My personal race-track to school is a ball-tearer.
Shit that is hi-tech.ME 109 wrote:I used a computer aided system I found in the shed.
Here is a soda blaster on the cheap for those little jobs, can be used on carburators and possibly other small parts.
http://www.aircooledtech.com/tools-on-t ... a_blaster/
1974 R90/6 built 9/73
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
1987 BMW K75S
1994 BMW R1100RS
1964 T100SR Triumph
1986 Honda XL600R
I used that method a couple of times with surprisingly good results. I helps to be able to buy the 5# boxes of soda though.jagarra wrote:Here is a soda blaster on the cheap for those little jobs, can be used on carburators and possibly other small parts.
I got by for years with the same trick Charlie, used a loctite product specially for bearings. Mine had so much clearance I wrapped a feeler gauge around it to take up the slack!Airbear wrote: I've just epoxied the outer race back into Brunhilde's rear hub. It was good for about 8000kms last time I did it. I suppose I'll eventually get around to getting it sleeved, but it sure is nice to be back on the road again.
Thnaks for the article on the soda-blaster jagarra. Neat and cheap. I like it!
Harbor Freight has it by the 40# bag.KenHawk wrote:I used that method a couple of times with surprisingly good results. I helps to be able to buy the 5# boxes of soda though.jagarra wrote:Here is a soda blaster on the cheap for those little jobs, can be used on carburators and possibly other small parts.
