![Smile :)](./images/smilies/icon_e_smile.gif)
Thanks for any responses in advance.
I ride on the parkway and some of the expansion joints are rather "crater like". I am so worried that a small tire like that is really going to damage my rim. I try to slow down but they are brutal. Hence, a bigger tire may have more protection for me.Seth wrote:If you are a mileage, non-acrobatic rider, why do you want a larger front tire. It will slow down steering response as it raises the front end increasing trail and the added weight increases gyroscopic force. Also, if you really make a tire wider, when you lean over in a turn, you may be lifting the bike which increases effort. Still, you've got fairly narrow wheels, so wider tires get pulled in at the bead. The stock 3.25 or 100/90 tire is perfect and should be matched with a 4.00 or 110/90 rear. So the only reason is if you think it looks better.
I probably ride a bit harder than you do and like the Michelin Pilot Activ or Bridgestone BT-45, but lots of people who ride like you really like the Bridgestone S11 Spitfire, which is probably a good choice.
A tire that is too wide will not protect your rims any better than the stock size...perhaps less. Think of the sidewall and how it absorbs the forces. An oversized tire will have a sidewall profile that splays...like: / \ The stock size sidewall will be more upright...to operate as it was designed...like: | | Bias ply tires have very stiff sidewalls (relative to radials) which are designed to be part of the suspension.fck wrote:I'll try a 3.50 and see how that works. Hopefully my aluminum wheels may experience a bit let bashing.
Not a waste. Actually many after market fork braces will improve handleing and steering, even on non-acrobatic rides. The original brace was way too flexible. Which one are you using? The key is to make sure your forks are aligned properly after installation. A good test for this (although not definative) is to see if you can push the front axle in with minimal effort.fck wrote:Ok. So the current thinking is that I should keep the regular tire that I have been running on the front. By that I mean the stock tire that they call for. I appreciate the replies! I guess I spent that money for a larger fork brace was a waste
