Got it warm and took a compression test when warm. Not wonderful. Just around 110 in each cylinder. Book is in KG but I figure I am in the area of poor to just below normal. Figure I may have to rebuild the motor. So what is the consensus, have a pro do it. Do it myself ( I do have extensive mechanical experience) and farm out processes like valves and boring?
The bike starts easily, no smoke, no leaks, everything appears to be original, including the tranny. I did find one obnomily on one carburator, just couldn't find a wrench to fit the nut on the choke lever, tried everything in metric and 'merican, turned out someone sneaked a whitworth nut on there
Whats the trick on getting the tubes back onto the air cleaner snouts, haven't learned the BMW secret yet. Thought about removing the stop tabs on the tubes, but then the hose has a step in it, so that was out.
thanks,
gg
