Brake light
lelocp
Brake light
Post by lelocp »
I just redid the wire harness on my 1971 r75/5 and for some reason the brake light stays on. Any ideas what could be causing the problem. Also what wires should i examine that would be associated with brake light staying on
Deleted User 62
Re: Brake light
Post by Deleted User 62 »
If it's the rear switch the nut and bolt on the rear brake lever that actuates it can be adjusted further toward the switch. Same on the handlebar switch, but you have to adjust the switch itself further in to the perch.
Re: Brake light
lelocp wrote:I just redid the wire harness on my 1971 r75/5 and for some reason the brake light stays on. Any ideas what could be causing the problem. Also what wires should i examine that would be associated with brake light staying on
Very simple. There are two switches. Disconnect the wires and see which it is. Then adjust the thing correctly.
