Squealing Brakes
Re: Squealing Brakes
That appears to actually be copper anti-seize. If so, it may or may not be effective for that application, but it's not what it was designed for.
dwire
Post by dwire »
Major Softie wrote:That appears to actually be copper anti-seize. If so, it may or may not be effective for that application, but it's not what it was designed for.
I'll second that (copper ant-seize appearing) notion. Also keep in mind the tiniest amount of grease can cause instantaneous lock-up on any brake. I'd also be worried with that much crap on there that washing the disc down after assembly would cause that greasy looking stuff to wash onto the disc; but perhaps not...
I might also add, the copper anti-seize has its place, but while working on our mostly aluminum BMW's, I would move the copper paste behind the aluminum looking paste in your cabinet as the interaction between the copper paste and anything (BMW or otherwise) aluminum is a no-no...
1971 R75/5 (SWB)
dougie wrote:
SteveD wrote:That copper coloured stuff is touted as reducing brake squeal too. It's tenacious like a bush oyster from a smoker!
I hope it's tenacious because there sure is a lot of it!
Yeah, I was surprised when I opened it up. There's gobs of it, but none on the friction surface of the pad. It looked well contained where it was applied.
Anyhow, all gone now and replaced with a specific brake rubber grease in a more sensible amount.
dwire
Post by dwire »
SteveD wrote:Yeah, I was surprised when I opened it up. There's gobs of it, but none on the friction surface of the pad. It looked well contained where it was applied.
What is "specific brake rubber grease?" Where does such grease go?
1971 R75/5 (SWB)
It goes where the copper stuff is...over the rubber seal that protects the piston and caliper bore. It keeps the seal supple and prevents it drying out I guess. It can also be smeared over the rear of the brake pads as that area interfaces with the seal surface anyhow. Brembo can supply this grease or any old brake rubber grease from your local autoshop will do. I use this...
dwire
Post by dwire »
Just curious, where did those instructions originate from?
1971 R75/5 (SWB)
dwire wrote:Just curious, where did those instructions originate from?
The ones in the picture? I did 'em. It's how the local BM privateer shop does them, and how Motobins suggest it gets done too. They sell a small package of grease to go with the seals and pistons in the kit.
It's also suggested and claimed that a dab of grease on the back of the pad can stop brake squeal.
dwire
Post by dwire »
I know better than to try and help here, but on the flip-side I am amassing quite a lot of material for my book. lol 8-)
1971 R75/5 (SWB)
moosehead
Post by moosehead »
Wow...8 pages on squealing brakes....
I'm afraid to ask this...but ...here goes....
My rear wheel disc brake "hums" when I push the bike backwards....about B flat I think....
Any ideas on cause/remedies...perhaps F sharp would be nice. :twisted:
Oh yea, bike is 82 RS with, obviously a rear disc that sings....
I await the choir :mrgreen:
Manfred
Location: on a mountain near Gowen, OK; on a 1987 R80RT
Post by Manfred »
How often do you push your bike backwards? I suggest the best way to avoid that noise is to ride the bike - forward! :lol:
There is therefore now no condemnation to them which are in Christ Jesus. (Romans 8:1)
