Chuey wrote:Hola, Mak. It's good to see you got the bars. Did you know you were buying them from me?
Those are some that I bought quite some time ago. I had them powdercoated and gathered up some really nice SS hardware for them, as they came with funky bolts/nuts and thin washers. I'm glad you like them.
I had decided to use weld on braces. When I use the weld on braces, they go from the lower end of the front main gusset back to just above the swing arm pivot housing. There is some triangulation with that set-up. I think that is what Major Softie is talking about when he says it goes from the center to the center. I had never installed those braces. I did make them look purdy, though.
Let me get this straight---You tarted the crappy poorly designed braces up and sold them so you install the proper ones.
I would have just cut my losses and tossed them. That doesn't seem right.
