Karcoma blues
Unclviny
Karcoma blues
Post by Unclviny »
1973 R75/5:
Saturday night I was riding home and the R75/5 was running fine but when I let it idle-down it would just idle-down to nothing, I felt like it was starved for fuel.
I looked today and the right Petcock flows like it should but the left lets a drop through about every 4 seconds! (I had a school for work for the last 3 days) so today I drained the full-tank and removed the left Petcock which appears to be packed (almost) solid with tank-liner, I can't get (very much) air or water through the thing.
There are no rebuild kits in town and I need the bike saturday, luckily there is a new Petcock on the shelf at my local-BMW-dealer.
I love my Bavarian Money Waster sometimes!, the tank has been "shedding" liner for a while now so this wasn't a complete surprise.
Vince
1973-1/2 BMW R75/5 (LWB)
1971 Norton Commando
1952 Triumph TRW
1936 BMW R2
dougie
Re: Karcoma blues
Post by dougie »
Unclviny wrote:so this wasn't a complete surprise.
Vince
Back at the factory they would say it was your fault. :o
Nasty buggers. :evil:
mattcfish
Re: Karcoma blues
Post by mattcfish »
Strange... My highly modified /6 will run just fine on 1 pet cock, even at full throttle.
A clogged petcock is a problem to fix, but it shouldn't effect idle if the other one is flowing.
Bellingham, WA USA
1975 BMW R90/6
1975 BMW 2002
1971 VW Westfalia
1985 VW Vanagon
Re: Karcoma blues
One petcock isn't enough flow under certain conditions. Besides, it is risky, so why allow it. Always assure full fuel flow through both petcocks.
Re: Karcoma blues
I've never experienced an issue with running on one petcock, even wot in 5th on long straights.
It's hard enough remembering to turn off one fuel tap, let alone two. :roll:
Re: Karcoma blues
ME 109 wrote:I've never experienced an issue with running on one petcock, even wot in 5th on long straights.
Same here.
Unc, would some compressed air thru the tap clear it?
Re: Karcoma blues
Yes Steve, that is for emergencys only, as it is temporary.
Our race bike woulnd't even run to top speed with both petcocks on and a low fuel level. The petcocks can become your main jets and that isn't good.
Unclviny
Re: Karcoma blues
Post by Unclviny »
I tried clearing it with air, water and shock and the tank-liner-bits seem to be keyed in there very-well. I went to my local dealer this morning and he had them on the shelf (they are 90 degree outlets so I got both-sides), $83.00.
I have the bike sitting in the sun with both Petcocks off and the cap open, my plan is to wipe-out the inside with a curved-rod with a small towel taped on the end to get the loose-stuff off and blow the tank out with an air compressor and a blowgun.
Vince
1952 Triumph TRW
1936 BMW R2
Re: Karcoma blues
Remove the tank, insert many nuts and bolts, shake well and clean out.
dougie
Re: Karcoma blues
Post by dougie »
Duane Ausherman wrote:Remove the tank, insert many nuts and bolts, shake well and clean out.
+1.
I also did varsol, soap and water, and sunshine after the nuts and bolts.
You could also consider POR-15, but that's a big job. (Ain't done it yet.)
